2000 Gs 300 Serpentine Belt help
Old 06-29-13, 07:49 PM
coolbeing
coolbeing's Avatar
Default 2000 Gs 300 Serpentine Belt help
I replaced the cam seals/ timing belt, tensioner/ water pump/ valve cover seals. Now I get to the last step of puttiing the new belt on and I can't get it on. I compared to the old one and they are exact. I even tried to reinstall the old belt. I have pushed the tensioner all the back and it has bottomed out. Are there any other adjustments that I may have missed. Help please. Spent a entire day replacing all these parts and I am lacking one step. Thanks,
Old 06-30-13, 12:21 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
the hydraulic tensioner can't be installed in the engine - you have to first run the timing belt, then bolt in the hydraulic tensioner... this will tighten the belt noticeably... I usually spin the motor 360 or 720 degrees at this point to make sure everything is lined up properly... then remove the grenade pin from the tensioner, good to go...
Old 06-30-13, 01:02 AM
SynicalVip
SynicalVip's Avatar
So you got everything else installed etc except for the drive belt/serpentine belt? I have encountered this issue before but not sure if it may be the same with yours but the problem I had was the whole serpentine belt tensioner assembly was no good, although I was able to loosen it a bit but still not enough to route the belt around all the pulley. So went and bought the whole assembly, swap it out and belt went right on
Old 06-30-13, 06:35 AM
burny
burny's Avatar
You are not talking timing belt, but Serpentine drive belt, right?
Old 06-30-13, 07:59 AM
mitsuguy
mitsuguy's Avatar
Yah, I just re read the title, was thinking timing belt not serpentine belt... which should go on easily so long as it is routed properly...
Old 07-01-13, 09:49 AM
coolbeing
coolbeing's Avatar
I replaced the tensioner and it slipped right on. Thanks for the help.
Old 07-01-13, 05:59 PM
SynicalVip
SynicalVip's Avatar
Great news!! Glad to hear
lnguyenh
04-09-11 07:28 AM
Farino81
Performance & Maintenance
06-09-09 08:54 PM
cocora64
05-30-08 04:43 AM
harryliu
Performance
11-23-04 01:39 PM
Quick Reply: 2000 Gs 300 Serpentine Belt help
