PCode help...please... :(
Hello,
Hoping somebody can shed some light on a list of codes I got on my 2007 ES350.
While driving last night - about 2 minutes into the ride my check VCS digital display came on, ecl light and TRAC indicator came on. I read through these threads before posting and see many have experienced this...using everyones past recommendations, I headed to AutoZone to get the Pcodes. Now that I have them, I am lost as to what to do with them.... Can someone help fill in the blanks/confirm and maybe even help me understand what they mean before I rush off to the dealer and spend money I cant afford to waste at the moment?
Here are the codes: (Ive notes beside each, what I was able to find for them - feel free to correct...
P1201 - brakes/calibers
P0371 timing reference High Res A too many pulses
P0057 oxygen sensor
P1271
P1272
P1273
P1274
P1275
P1277
P1278 air fuel ratio
P1281
Pardon if the answer to these is obvious - Im a girl - who admittedly knows very little about this...but appreciate any insight any of you may be able to offer....
Thank you in advance.
P0057 oxygen sensor
P1271
P1272
P1273
P1274
P1275
P1277
P1281
This is what I found on TIS. I am unsure why Autozone pulled so many DTCs from the vehicle that do not exist. If you only focus on the P0057, it is likely that you have a failed Bank 2 Sensor 2 O2 sensor.
P1201 - Not a valid DTC
P0371 - Not a valid DTC
P0057 - Oxygen Sensor Heater Control Circuit Low (Bank 2 Sensor 2)
P1271 - Not a valid DTC
P1272 - Not a valid DTC
P1273 - Not a valid DTC
P1274 - Not a valid DTC
P1275 - Not a valid DTC
P1277 - Not a valid DTC
P1278 - Not a valid DTC
P1281 - Not a valid DTC
wzwz8221
12-16-12 05:10 PM
