05 LS430 rear wheel alignment part #
Recently I had the 05 LS430 alignment done. Tech said that I need to replace some parts on rear suspension because joints are maxed out and cannot correctly align the car.
Would you happen to know what parts they are please? Are there aftermarket parts that are more adjustable than OEM?
Thank you
Thank you
Maintenance Moderator
Two options... Option 1 is to go with a FIGs engineering adjustable bar, $330 a side give or take and gives almost infinite adjustment, Option 2 is a shorter lower rear control arm. This will give you a fixed .75 degree camber change towards the positive (less negative), these run $160-$200 depending on where you purchase them....
I don't know part numbers off top of my head, sorry...
leisinjp
12-01-18 08:39 PM
skassamali
07-23-11 01:05 PM
