help with changing differential oil and transmission fluid
how do i change the differential fluid in my 92 sc300...how much transmission fluid should i get and what kind? how hard it is to do, if done oil changes and alot of other stuff(lowering cars, putting in cold air intakes, etc) with my friends on there cars, I wouldnt think this would be hard at all.
I have performed the two services myself on my SC400. It is very easy to do. The differential has two bolts. One to drain, and one to fill. Open the one on top (filler) first, and then open the drain plug on the bottom. Once all fluid has drained out, replace the bottom plug. Next, insert diff fluid in the top filler plug until it begins to overflow. Replace the plug, and you're ready to go. I used a Valvoline 85W 90 synthetic blend in mine, and it has worked great. Check your owner's manual for the exact weight of diff fluid.
The SC400 calls for the Toyota type IV tranny fluid. I think the SC300 is different. You probably just need Dexron III fluid. Buy yourself 5 quarts, or so. That way, you'll be sure to have enough. Again, if you want exact amounts, check your owner's manual in the maintenance section.
You may want to consider...
Having the transmission flushed-where they replace all the fluid in the system (8 qts or so) rather than the 2-3 qts changed during the traditional fluid route (dropping the pan)
If you do a search on 'transmission flush' you'll find that someone posted a link to do this flush yourself (too much for my feeble brain) if you do a search for posts by me (bradster) you'll come across my recent post about my tranny flush (1990 LS400) done by a local Lexus dealer.HTH!
ok...ive been searching through the forums and i figured out how to do a trany flush. now what kind of transmission fluid do it need for my 92 sc300, where should i get it and how much do i need and how much does it cost?
BlueCrabby
RX - 1st Gen (1999-2003)
09-04-15 07:10 AM
LocalIS300
IS - 1st Gen (2001-2005)
06-29-15 03:36 PM
