Lexus GX460 Rust and Undercoat / Rustproofing In Salt Infested Road
Old 11-04-14, 06:45 PM
mikereyes7
mikereyes7's Avatar
Default Lexus GX460 Rust and Undercoat / Rustproofing In Salt Infested Road
I got a 2013 Lexus GX460 and I live in Toronto. Winter here can be very harsh with roads muddled with salt - hence corrosion. I am confused as dealership and Lexus site do not recommend undercoating but it will definitely help prevent corrosion especially with the salty roads in Toronto during winter.
Should I undercoat or not? I don't want to void any warranties if I do the undercoating yet Lexus does not recommend it. But if I do not undercoat, rust will build up unless the 2013 GX460 is factory protected from rust.
Will appreciate any thoughts/ideas on this.
I asked about undercoating and the Lexus dealership told me and from Lexus correspondence itself, "As Lexus Canada does not offer this type of product, we cannot endorse the use of after market rust proofing. This does not mean that it will not be beneficial to your vehicle, it simply means that the decision is at your discretion.
With regard to the effects of after market rust proofing on your vehicle's manufacturer's warranty, should the application of this product be the direct cause of a concern with your vehicle, Lexus would not be responsible. As you can certainly appreciate, the manufacturer's warranty will cover defects in material or workmanship and not difficulties arising from factors other than the manufacturing processes."
Old 11-08-18, 05:44 AM
peasodos
peasodos's Avatar
Received 2,229 Likes on 1,450 Posts
Waste of money with the under protection the car already has.
Old 12-01-18, 05:14 AM
ShrinkDoc
ShrinkDoc's Avatar
We get tons of snow and road salt. I did the undercoating at Zeibart. Zero regrets!!! The car (2014 IS 350 F Sport) had rust in several of the seams and beneath the door frames (so much for the rust-proofing at the factory). Lexus indicated that the rust was considered part of the wear and tear of driving in the area--essentially, you are on your own if it occurs one day after the bumper to bumper coverage is gone. My suspicion is that you would be on your own even under coverage.
They cleaned it off and sprayed the oily tar substance inside the wheel wells, inside the doors, and under the car (except the exhaust). It comes with a 10 year warranty.
Cost--$539!
Old 12-01-18, 04:28 PM
ArmyofOne
Dysfunctional Veteran
ArmyofOne's Avatar
https://www.clublexus.com/forums/mai...rust-away.html
ALWAYS use an undercoat if you live and travel in salty areas.
ShrinkDoc (01-19-19)
buch
RC F (2015-present)
08-04-15 08:47 AM
yycdave
03-08-14 05:55 PM
Leonard15
07-02-09 07:20 PM
SC3coupe
06-29-07 09:53 AM
Quick Reply: Lexus GX460 Rust and Undercoat / Rustproofing In Salt Infested Road
