High Flow Fuel Injectors?
I own a 2002 Lexus sc430.
Does anyone have any experience with installing high flow fuel injectors? I read that upgrading the injectors is useless because an ECU tune is necessary, which is not possible on our cars? Is that correct? Are upgraded fuel injectors a waste of money?
I found some modified OE fuel injectors with a higher flow rate at Fiveomotorsport that are interesting.. Any questions, comments, or critisisms are welcomed!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
You will have to re-map the ECU for different injectors....but you don't need to since your engine will never max out the injector cycle.
6SOARER
SC400 / 300 Classifieds
09-09-13 09:16 PM
tonysc400
01-31-13 10:44 AM
BAD954BOI
10-04-12 02:35 PM
