Oli filter location on GX470
Right in front man, just remove the first skid plate "heavy metal one" should be 4 bolts and the oil filter sits right up in front, other part of the skid plate does not need to be removed it has a pop out peace that is directly right under the drain bolt, sort of oval shaped stick your hand in and push pop it out
