How to get to valve cover
Hi All,
I have a 2002 sc430.
I tried to take off my drivers side valve cover to repair the leaking gasket.
There is so much junk in the way I could not get to it.
I removed around a dozen 10mm bolts, but there is still an electrical relay I cannot remove.
There are several electrical connectors towards the front of the vehicle, and I unplug all but one (couldn't find it went down into the lower front part of the car in a maze),
Any tips on how to get to the drivers side valve cover?
Is there a trick to this?
Maybe I need to get under the car?
Thanks!
Thanks!
I was just tightening my valve cover bolts on my 4.3 tonight. What a PIA trying to get to them. I can't help you with taking it off, looks like more of a pain then I first thought, you may want to try tightening the valve cover bolts(they get pretty loose) and also using a gasket rejuvenating product like Lubro Moly Engine Oil Saver or ATP 250 to see if that works to stop or heavily slow down the leak before you tackle that job.
LexBrett
04-02-15 01:27 PM
