Crank shaft replacement es 300 2005
Old 05-05-15, 08:39 AM
syedsami
syedsami's Avatar
Default Crank shaft replacement es 300 2005
Hi
I would like to know if I have the replacement done for the crank shaft pulley as per the recall in the campaign of Lexus. What are the differences it will make in driving ?
Will it improve the start ignition ?
Will it improve the hesitation of car?
Will it improve the transmission hesitation?
Because I read one of the posts which says I need to upgrade my software for transmission hesitation but the Lexus dealer says there is no such update on this . So wanted to us that will this pulley bring changes in driving mode or not ? It is a free replacement though ..
Regards
Old 05-18-15, 07:47 AM
GSteg
GSteg's Avatar
The crank pulley replacement will not change the way the car drives. They're only replacing the pulley because there is a chance the pulley's rubber damper may separate. The transmission hesitation is a different issue and is common among the 4th gen ES. I have one and sometimes it can't tell what gear it wants to be in. It's more of an annoyance than anything, but still terrible for "Lexus" quality.
dhsnyde1
16
09-21-23 08:32 AM
jstites
02-24-16 09:01 AM
gflvette2
08-15-10 10:44 PM
rahulc
07-27-08 06:09 PM
pushpin30
09-18-03 02:46 PM
Quick Reply: Crank shaft replacement es 300 2005
