I'll try here - brake upgrade - caliper bolts
Guest
Posts: n/a
This's gonna be a hard one to do. You're trying to convert a single piston on the 90 LS to a dual piston from SC430. You will need to replace a complete knuckle assembly along with wheel bearing/ may be wheels. Plus, you'll have to considering about the suspension set up between the 90 LS and 02 SC430, so forget about this project.
The 95 LS has 4 pistons set up. Like you said, the only choice you got is the 93-94 LS set up because of the similarity on the front suspension. Let us know how it turn out.
Lvangundy
10-15-02 03:17 AM
