95 Timing Belt Change (Part)
Ok I'm going to change the timing belt and all the other parts associated with it.
I'm buying the parts from a dealer recommended from this site and then I'm going to have my girlfriend's uncle's shop do the install (he said he'd do it all for $200).
What parts do I need for this job, like each and every part, I need to tell the place where I'm buying the parts which parts to ship.
Also, I'm going to do the plugs, plugwires, cap and rotor at the same time. Do I need anything else other then those parts?
Thanks
Thanks
Thanks
Thanks
I did some research and found these part's lists. Does anyone else have anythng to add before I go order these parts?
Part Number
1 x 1610050022 - Pump Assy, Water
1 x 1356859045 - Belt, TIming
1 x 9091602463 - Belt, V-Ribbed (Serpintine)
2 x 002721LLaC01 - AntiFreeze
1 x 9676124019 - Ring, O
1 x 9676135035 - Ring, O
2 x 9031138036 - Seal, Type T Oil
1 x 9031143006 - Seal, Type T Oil
This is what you need, but it doesn't include the Tensioner or Idle.
____
lvandgundy:
Timing belt = 68.33
Tensioner brg. (bearing) = 124.88
idler brg. = 98.53
crank seal = 11.54
cam seal = 4.90
water pump = 151.56
anti freeze = 11.86
air filter = 26.87
roguenode:
Idle Pulley 70.43
Timing Belt 89.52
Tensioner Pulley 108.36
Upper Hose 20.15
Thermostat Seal 1.23
Water Pump 140.97
Serpentine Belt 62.75
Thermostat 11.30
Coolant 8.90
Part Number
____
lvandgundy:
Timing belt = 68.33
idler brg. = 98.53
crank seal = 11.54
cam seal = 4.90
water pump = 151.56
anti freeze = 11.86
air filter = 26.87
roguenode:
Idle Pulley 70.43
Timing Belt 89.52
Upper Hose 20.15
Water Pump 140.97
Thermostat 11.30
Coolant 8.90
sho89mtx
04-02-12 01:54 AM
MarcusMIA
Performance & Maintenance
10-07-09 02:28 PM
