1991 ES250 Rear Wheel Bearing
How do I change the rear wheel bearing on my 91 250? I can't figure out how to get the hub off, and is it a sealed unit or is the bearing itself replaceable?
thanks
Justin
thanks
Justin
You have to remove the rear brake rotors and you will see an access hole to remove the bolts. The rear wheel bearing on the ES is bluid in with the hub. When you get the new one from Lexus/Toyota you will see.
