Lower Ball Joints
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Hello,
I have an IS 300 2003 & having a problem taking off the lower ball joints. I have taken off the castle nut, pin and 2 screws off the ball joint, driver's side. I loosened the castle nut on the tie rod end, took off the pin as well. I have used a pickle fork, ball joint separator & the ball joint does not move. A friend recommends for me to hammer the stud from underneath? Would that be the correct way to take the lower ball joint? As I mentioned before, I loosened both of the castle nuts but did not remove them completely. I did not use the pickle fork on the connecting tie rod end, should I have loosened it? I am all over it but just need to know what the best way is to remove the lower ball joint? I purchased 2 Moog brand ball joints, I hear they are a good brand. They are greasable & my mechanic friend said that is what he recommends. Please let me know your thoughts and thank you in advance.
John T AKA JT
John T AKA JT
Xatmedia (06-22-19)
