Growling water pump pulley/bearing? 2008 ES 350
hello
we have a 2008 ES 350 w/110k miles.
during the last inspection the service adviser said there is a growling sound coming from the engine and sounds like water pump bearing or pulley is on its way out and we need to replace the water pump.
there are no leaks visible.
does this sound right and is there an easy way to confirm that it is the water pump making this noise?
thank you
thank you
You are due to have changed anyway.so take the mechanics wise advice and replace it.
