weird window problem
this is on the drivers side- the top right hand side there is a black plastic screw that screws into window track thingy. Hopefully yall will know what Im talking about . well.... mine has came undone for the second time leaving a hole in the window where it is supposed to be. I keep getting new ones and screw them into place but rolling the window up and down makes it unscrew itself and fall off . Is there a way to make it stay there and not unscrew itself?
Hi,
I just installed a new cable assembly for my power window and noted that each of the screws you speak of had lock-tite on them. You can buy it anywhere and there are different strengths so start with the medium as these are screws so the strong stuff may make your screws a permanent fixture. I would only use the strong stuff if I was applying it to a hex head bolt.
Cheers,
James
Cheers,
James
I think i got you confused because it seems you are talking about a different thing which is not bad(my fault) this "screw" im talking about conects the window to the track on the right side , when not on there is a hole in the window. This is on my SC400. this black screw has a head about the size of a penny. I just need to figure out how to get the dang thing screwed in.
is it that little black button look alike thingie that moves like a screw if you push and turn it? oh yeah and it pulls up the window? but when it gets loose, your window doesnt work at all?
if it isnt, then deng there's something wrong with my windows..lol
yea its a little black screw thing that keeps the window sliding up and down the track.. Mines gone but the window still works( it struggles a little some)
oh yeah.. that's the one! well im about to get it fixed cuz i have that same problem.. uhm from what i was told..u have to take apart the door and retighten the screw from the inside or sumtin..beats me..but ill be sure to write down the instructions on how to fix it when the guy does it for me.. i'll post it up when im done.. sooo hopefully that'll help ya!
xspsi6
SC- 1st Gen (1992-2000)
06-04-15 06:04 AM
baodalazi
04-04-11 07:11 AM
