Brake pads change on 2014 IS (Gen3) Base
10th Gear
Forum - seeking your expertise and guidance on type and timing of changing my pads on my 2014 IS250 Base (Gen3) with 38k miles Are these original pads semi-metalic or fully ceramic?
I was almost sold on putting in an Akebono $55 or Wagner Thermoguard ($~$40). But called the dealer, for the past number and theirn parts said my model takes semi-metalic pads! Help, what is the right model and remlcomended pad to avoid a router mismatch or excess heat. Thank you.
