Need help 2000 RX300 timing belt ?
#46
Hey Nad, I removed cylinder #1 coil and it was dripping with oil badly, I mean half of it was submerged. I used shop vac to suck out all the oil.
#47
I actually had that same issue about 2 months ago.
#1 and 3 were oil soaked.
Had misfires while driving. Check engine light flashing.
Replaced the plug tube seals on the valve cover.
Where you able to check fuel or spark?
I know you had fuel spray on the line bolt, but that doesnt mean you have fuel delivery from the injectors.
