Battery Replacement...
I own a 1999 SC400, and this summer’s 115-degree temperature in Las Vegas has taken its toll on my battery. Lexus quoted me $95 for a replacement.
I have 2 questions;
(1) Is there a better after market battery I should consider?
(2) Is it as simple as disconnect and reconnect or is there something else I should be aware of?
Before I get booted for a battery question, I did a search first, and did not find a recent answer to these two questions.
I have 2 questions;
1) A better alternative is going with a dry-cell such as an optima. It will cost you more than what Lexus is charging you for a dealer battery, but you will get a longer lasting, more reliable and stronger battery. I dont see any difference between going with a Lexus factory battery vs one purchased from your local autoparts store.
2) No matter which type of battery you get, its a simple disconnect/reconnect. Just remember to take down the time and the radio station presets.
oh on the optima you will have to adjust the cables to fit the terminals..because the stock ones have terminals near the ends of the battery the optima has them loacted closer to the center...it shouldnt be that hard to adjust them but i thought i would let you know....
CEO
CEO
That's not a bad price for the stock battery. You will probably not want to go as low-brow as I did, but you can get away with a Walmart Everstart 24F, which cost me $29.95 (w/a 3 year warranty).
It's smaller/lighter than the stock battery, and so the stock battery cover will look oversized if you want to keep using it. It didn't look right, so I didn't use the cover. Other than that it fits, looks and works just fine.
EDIT/Update: Five years later, what a bargain that EverStart battery was- it lasted almost exactly 5 years - same as the warranty (not 3 years, as I said above).
It was still working, but would not hold a charge over a weekend, so back to WalMart I went to replace it.
What a difference five years makes - what the hell has happened to battery prices?
The WalMart MAXX-24FS that I just bought to replace my EverStart cost me $80!
The only consolation is that the WalMart MAXX line has a 10 year warranty.
I was tempted to get a cheaper battery however, your right, $95 from Lexus is not really that bad. Besides, if I have any problems with it, nothing beats the service I receive when I drive into the Lexus service drive. It's sometimes worth a few extra bucks.
The only place I could find a 24F locally was at Sears, and it ended up costing $110 for their DieHard International 24F battery. It was the same size as the Lexus-branded 24F battery it replaced. Lexus batteries are made by Interstate, and DieHard I believe are currently made by Johnson Controls. In retrospect, I would've just gone with a readily-available 35 for $30 or so. The smaller 35s don't have the recommended CCA for my LS, but it doesn't get cold enough for that to matter here in southern California.
I went to Lexus last night and picked up the replacement battery. Funny thing was, when they brought the battery out they told me they made a mistake, the 99 SC400 battery is $135. I did a little complaining and they gave it to me for $95 with a 2-year over the counter and 84 month prorated warrantee. It took me 5 minutes to swap it out. I too do not have cold weather cranking to worry about.
kreativ- I went outside to double check and its says "EverStart Part #24F-5". I was wrong about the warranty- it's free replacement for 12 months, then pro-rated up to 60 months (5 years).
I bought it after reading whitels' recommendation in the following thread:
https://www.clublexus.com/forums/sho...threadid=44884
At 650 CA and 525 CCA, those that spend their winters in Minnesota probably shouldn't use it but you're right- it does not matter much here in So Cal.
extremecc- I'm glad you didn't fall for the stealership's bait & switch- good going!
c'mon, fellers.....it may be cheap, it may be nice, and it may work, but is it really "clean"?
For all it is doing for you, you may as well schmear on some axle grease (yet another type of petroleum jelly).
I'm not saying that Vaseline won't work- just keep a rag handy. Personally, I've had good luck with those red and green felt washers that they sell at auto parts stores for 75 cents or so.
Ha!
Perry in LA,
Vaseline is a lot "cleaner" than axle grease. I rub vaseline on chapped lips and cracked hands and feet. I can't say I would really want to do that with axle grease. The kind of petroleum jelly I use is basically clear and all the axle grease I've seen is sort of brown and nasty looking. Were you trying to prove my point? THanks anyway!
WHat's cool is how once the battery posts get heated up, the vaseline will flow into all the little nooks and crannies. Now don't be a knucklehead and put a tablespoon on each terminal.
Just a little dab will do ya. I do this to my lawnmower, motorcycle, and all cars. I KNOW it works.
Of course, if you feel better about the little fuzzy washer...
Perry in LA,
haha....now, now, Gebo- notice I didn't say that Vaseline doesn't work, and in fact, maybe the best fix is to use BOTH. That way, when your Vaseline starts a-flowing, my fuzzies will keep it from dripping all over extremecc's nice new battery!
(And, if you got cracks in your feet, you don't need Vaseline, you need Desenex. Use it for 30 days straight- your locker room buddies will thank you
