LS430 rear sway upgrade
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I need to replace my caster bushings and struts. I am considering replacing the rear sway bar and links with the set from the Sport Package. It is easy, remove the stock set and bolt on the Sport Package set or do I need to do something more? I like the original ride and only wants to have less body roll. Any suggestions or advice, thanks.
That is how it works with every swaybar upgrade I have done on other cars. You could reuse your links if they survive being removed, which has a 50/50 chance. You should also get the bushings for the sport bar as it is probably a larger diameter. Good Luck and have fun!
