RPM is not workin
Does the pointer not move, or is the pointer burned out? There are two very different solutions, depending on which is your case. The pointer not moving would be a bad sending unit from the ECU to report RPM to the cluster, the pointer burned out is just that--a common problem on Lexus vehicles built before and up to the 1996 model year.
SpruceRain
11-06-23 07:54 AM
