2020 RC350 RWD - Correct transmission temperature range to check fluid level
1st Gear
Hi All,
What is the correct trans fluid temp range to check the fluid on a 2020 RC350 RWD with the AA81E transmission?
I've see some documentation for IS350's with the same trans that say from 97-126 degrees F.?
I was just going to shoot for 100 degrees to pull the overflow bolt.
Thanks!
Thanks!
