Have 2-channel RF 1050S need a 500-1000W Mono block/// Trade?
Have 2-channel RF 1050S need a 500-1000W Mono block/// Trade or Sale
I have a 2-channel Rockford Fosgate Power 1050S with remote bass control. It is rated at 262.5W RMS per channel at 4-ohm, 525W per channel at 2-ohm, or 1050W RMS bridged at 4-ohm. I have a single DVC Audiobahn with 4-ohm coils, so I am only able to take advantage of one channel on this monster. The amp is in immaculate shape, no problems or visual blemishes. I do not have the end caps that cover the wire connections, but I called RF, and they have them in stock for $21 for both of them shipped. I have no problem leaving this amp in the truck, but I kind of feel like it's a waste with another 525W sitting there unused. If anyone is running 2 4-ohm DVC subs on a 500 Mono block, this is the deal for you. You upgrade to 525 times two. I'm open to Memphis, JL, Alpine, Kicker, Pheonix Gold, ect. Basically no junk. If anyone wants to deal, just reply, or shoot me an E-mail. BRANDONCWADE@SBCGLOBAL.NET I can also sell the amp for $330 as is, or $350 (I'll get the end caps).
Sorry, I do not have any way to upload pictures, but you wouldn't be able to see a difference between this one and a new one anyways. This amp retailed for $999 new.
Brandon
262.5 watts RMS x 2 at 4 ohms
525 watts RMS x 2 at 2 ohms
1050 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
Tri-Way capable
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
variable 50-250 Hz high-pass/low-pass crossover, 24 dB/octave
MEHSA — a process that transfers heat from the MOSFET output devices to the heatsink more efficiently than traditional methods
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
TRANS•ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
Phase Warp feature adjusts the phase of the output signal for maximum performance
preamp outputs
wired remote control of Punch Bass (up to 18 dB of boost centered at 45 Hz)
100-amp fuse (or two 50-amp) and fuse holder required
dimensions: 18-7/16"W (14-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
Brandon
Tri-Way capable
preamp outputs
TruPlaya26
30
06-30-08 01:33 PM
