FS-Xtant 202m
Originally posted by TruenoHatchiRok
quick question, what is that? sub or amp? (my friend is looking for an amp)
btw, finally installed the 2100b! sounds great! Thanks again!!
*Bump for a great seller!*
Keeper of the light
It's just so TY-KNEE i have had both the 2m, 3m and 4m before. (i like the 4m best )
Here's is the biggest delimma..... it is a monoblock amp. it doesn't have but one channel. I would have to run that on my sub and use the 301a MAX on my mids. That put's me down in power on my sub. BUT i'll do it to get my system going in my BImmer. I just gotta be able to let the price justify dropping my power to my boom.
Keeper of the light
I'm an ex car audio store owner. It's one channel
It has two outputs so you can attach multiple speakers. It tricks people sometimes. Hence the "M" in the 202M MONO-BLOCK. Single signal outout, combines left and right on the input and if you open the amp up, the two outputs are coming off the same transistor. They are literally tied together. It's like splitting a fork. It didn't help that Xtant gave it a split channel power rating... why i will never know.
I'll holla at you on what i decide.
Thanks.
http://home.comcast.net/~bcrowder19/godz2.jpg
http://home.comcast.net/~bcrowder19/godz3.jpg
http://home.comcast.net/~bcrowder19/godz4.jpg
http://home.comcast.net/~bcrowder19/godz5.jpg
Thanks.
I used to seel car audio also..
The xtant 121m was a mono amp
1x125@4ohms
1x250@2ohms
bridged-N/A
202m 2-channel
2x50@4ohms
2x100@2ohms
1x200@4ohms bridged
404m 4-channel
4x50@4ohms
4x100@2ohms
2x200@4ohms bridged
I have all of the specs for every xtant made and their installation features before mtx bought them..the 202m can be used for a sub or to push mids and highs all you have to do is change the crossover...You wire up either 2 -4ohm speakers and get 50watts each or wire 4-4ohm speaker and get 100 watts out of the amp..I was using 2-202m amps to push a set of boston pros and later upgraded to 2200ix.. let me know..
1x125@4ohms
1x250@2ohms
bridged-N/A
202m 2-channel
2x50@4ohms
2x100@2ohms
1x200@4ohms bridged
404m 4-channel
4x50@4ohms
4x100@2ohms
2x200@4ohms bridged
