FS: Sub box for JL Audio 10W7
I've upgraded my sub so I have a sealed sub box available for the JL Audio 10W7 for sale. The box is professionally made by Acoustic Dimensions using 3/4 MDF, 12 braces, and 2 standing wave boards.
It is glued/sealed w/ silicon and 2.5 inch brad nails. Also, the face is 1.5 inches thick and the box is covered in OEM grey factory carpet to match the trunk carpet.
Perfect for someone who has or is looking for a JL Audio 10W7 sub or a sub requiring the same specs. (1.25 cu. ft.)
Asking $70. NorCal pickup or delivery. I left the box at the shop in case another customer wants it but I can get pics of it if anyone is interested.
Thanks, jd
Thanks, jd
pics of the sub enclosure
The shop has been REALLY slow w/ sending me the pics. They're supposed to send them tonight. But, if they don't I'll be out there this weekend so pics should be posted in no later than a few days.
Thanks, jd
Thanks, jd
actually, here is a pic of the old box installed. rear deck? yes. but i don't recall if you'll have enough space (depth) for the stock 10" sub. also, i sold my stock sub so i can't try it for you.
thanks, jd
thanks, jd
pics posted...
for those interested, here are the pics of the box. sorry for the delay.
John, I got your PM and replied w/ my #. I'm back in town so let me know.
Specs once again:
Professionally made by Acoustic Dimensions using 3/4 MDF, 12 braces, and 2 standing wave boards. It is glued/sealed w/ silicon and 2.5 inch brad nails. Also, the face is 1.5 inches thick and the box is covered in OEM grey factory carpet to match the trunk carpet.
1) box w/ polyfill
2) 1.5" mounting plate around the box and brad nails
3) back of box (construction)
4) inside of box (bracing and wave board)
5) inside of box (more bracing, other wave board)
6) polyfill
Specs once again:
1) box w/ polyfill
6) polyfill
Originally Posted by b1gredek
too bad you are up north or else i would pick this up for my jlw7
SUb box
do you still have this box for sale?
question...how deep does it fit in the trunk space? From the pic it looks like it fits pretty flush. Is there any room from the panel behind the back seat to where the box actually sits? I have an amp mounted on behind the back seat so thats why I ask. Would there be any room or is the box designed to fit perfectly with no gap between the back seat?
thanks
also, would i be able to cut the hole and make it larger to fit a 12" woofer?
thanks
thanks
thanks
the box is made to spec for the internal volume required for the 10W7 including the bracing and wave boards. you would need to check the specs for whatever 12" woofer you have and compare the required internal volume. PM me w/ your subwoofer info. or if you're interested in a custom box for your 12. i do have a ported box for a 12" Diamond Audio TDX woofer also since i might be trying a bandpass box next.
thanks, jd
