FS: Stereo Stuff-Amps-Sub- Cap
Like it states I have for sale 2 Alphasonik amps model numbers are PMA 1200DA and PMA640 HCA both have been bench tested and are in 100% working order also I have a Lightning Audio 1 farad cap Finally a 18 JL Audio sub in a ported box !! here is the specs of the amps I prefer local buyer for the sub and box I will ship amps and cap.Iam only selling to finish another project that I started or Id put this in my car.There will be no refunds on electronics due to installation error like I stated before THESE AMPS WERE BENCH TESTED AND ARE IN 100% WORKING ORDER !! I would like to sell the amps together if possible.None of the seals on the back of the amps were broken or tampered with !! Pics will be up later .Iam pricing this stuff for a quick sale so please no low balling
Product Description: PMA 1200DA class d
1-Channel Class D Mono-Block Power Amplifier
RMS power Rating:
o 1200 watts x 1 @ 4 ohms mono
o 2000 Watts x 1 @ 2 ohms Mono
o 2470 Watts x 1 @ 1 ohms Mono
Bridgeable with Second Identical Model
Hour Meter
Optional Remote Mount Digital Voltmeter Gauge
Optional Remote Mount Bass Boost Control
Heavy Duty One-piece Extruded Aluminum Heat Sink
Variable Low Pass Filter: 50Hz~150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz~40Hz, 24dB/Octave
Variable Bass Boost at 45Hz: 0~+ 18dB
Variable Phase Shift: 0~180°
Input Impedance: 10K ohms
Variable Input Sensitivity: 300mV ~ 8V
Tiffany-Style Input and Output RCA Jacks
Parallel Line-out RCA Jacks
Removable Covers Conceal Control and Terminal Panels
MOSFET High Speed Switching Power Supply
Milspec Double-Sided Glass Epoxy Circuit Board with Through-hole Plating
Heavy 4 oz. Pure Copper PC Traces at All Preamp and Amplification Stages
Internally Mounted Fan-Cooled Power Supply
Solid Brass Nickel-plated Terminal Blocks (4-gauge Power, 8-gauge Speaker)
Terminal Blocks are Compression Type and Soldered Directly to the PCB
4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
Dimensions: 20-7/8 L x 9-1/8 W x 2 1/2 H
Amplifier Specifications:
Number of Channels: 1 - Mono
RMS Power (4 ohms): 1200 watts x 1 chan.
RMS Power (2 ohms): 2000 watts x 1 chan.
RMS Power (1 ohm): 2470 watts x 1 chan.
Bridged RMS Power: Not Bridgeable
Peak Power Output: 5000 watts approx.
Min. Impedance Unbridged: 1 Ohm
Min. Impedance Bridged: Not Bridgeable
THD @ Rated RMS Power: 0.05%
Speaker Level Inputs: No
Amp Preamp Outputs: Yes - 1 Pair
Built-in Crossover: LPF(50 - 150 Hz), Subsonic(15 - 40 Hz)
Bass Boost: 0 - 18 dB @ 45 Hz
Signal-to-Noise Ratio: 100 dB
Fan Cooled: Yes
Fuse Rating: N/A
MSRP $1299.00
Product Description: PMA 640 HCA high current
4-Channel High Current Power Amplifier
RMS Power Rating:
o 160 watts x 4 chan. @ 4 ohms
o 290 watts x 4 chan. @ 2 ohms
o 490 watts x 4 chan. @ 1 ohm
o 500 watts x 2 chan. @ 4 ohms bridged
o 825 watts x 2 chan. @ 2 ohms bridged
o 960 watts x 2 chan. @ 1 ohm bridged
Hour Meter
Optional Bass Remote
Heavy Duty Heat Sink
1 Pair RCA Outputs
Variable Low-Pass Filter: 50 - 250 Hz
Variable High-Pass Filter: 50 - 250 Hz
Variable Subsonic Filter: 15 - 60 Hz
Variable Bass Boost @ 45 Hz: 0 - 18 dB
Input Sensitivity: 200 mV - 8 V
Input Impedance: 10,000 ohms
4-Way Protection Circuitry: Thermal, Short-Circuit, Overload, and DC Offset
On-Board Hook Up Terminals
Frequency Response: 5 Hz - 50 kHz
Dimensions: 19-3/4" L x 9" W x 2-5/8" H
Number of Channels: 4
RMS Power (4 ohms): 160 watts x 4 chan.
RMS Power (2 ohms): 290 watts x 4 chan.
RMS Power (1 ohm): 480 watts x 4 chan.
Bridged RMS Power: 960 watts x 2 chan.
Peak Power Output: 3840 watts approx.
Min. Impedance Unbridged: 1 ohm
Min. Impedance Bridged: 1 ohm
Built-in Crossover: HP (50 - 250 Hz), LP (50 - 250 Hz), Subsonic (15 - 60 Hz)
Fan Cooled: No
Fuse Rating: 80A
MSRP $949.00
PMA 1200DA class d MSRP $1299.00 my price $350.00 shipped (very heavy)
PMA 640HCA high current MSRP $949.00 my price $325.00 shipped (very heavy)
Lightning Audio power cap my price $45.00 shipped
JL Audio 18model 18w3 sub and ported box $150.00 local pickup only
RMS power Rating:
Hour Meter
Fan Cooled: Yes
Fuse Rating: N/A
MSRP $1299.00
RMS Power Rating:
Hour Meter
1 Pair RCA Outputs
Fan Cooled: No
Fuse Rating: 80A
MSRP $949.00
ill tell u that i have ran alphasonik amps HARD in my car for 2 years and they work GREAT!!!! great quality.. i paud over 1800 for one of my amps
great deal
also shawn is a great guy to deal with
great deal
great deal
great deal
