Phoenix Gold Octane R 5.0:4 FS
I bought this 2 months ago.... but it's only got about 3 weeks of use because I bought it to be used with my carputer system (which took me a while to configure). Well now I've decided to go with a 5.1 surround system and need a 5 channel amp. So I'm selling this (or trade if you have a 5 channel)
its in perfect working condition. It just has a slight scratch towards the top of the amp. Everything else is fine. Will come with original box and stuff. The thing i liked about this amp is the seperate gain AND crossovers for front and rear. You can make the front highs and rear lows, or a combination of them... or bypassed altogether. Also comes with bass boost if you're using it for subs.
Only asking 165 shipped.
ummagawd@gmail.com
[IMG]javascript:enlargedImage('http://www.cardomain.com/shop/view_large_image_frameset.pl?sku=PHOR504')[/IMG]
SPECS
Designed and engineered by the same crazies that brought you the other Phoenix Gold amplifiers, the new Octane-R series offers quality and performance at prices that won't take a huge bite out of your wallet! The Octane-R features a striking black anodized heavy-duty heat sink with a grained aluminum insert and an LED backlit carbon fiber badge. The Octane-R series has all the features you would expect in a high-end amp: Continuously variable crossover, Twin "T" bass boost, and 1 ohm stability. A Remote Monitoring Display (RMD) port allows the addition of an optional voltage monitor, allowing you to keep an eye on how much juice is being delivered to the amp. You can even customize your new Octane-R amplifier with an optional neon lighting kit. Octane-R amps provide all the high-octane power your speakers can handle.
Features:
* Grained aluminum insert with carbon fiber badge
* Blue LED backlit PG logo
* Independent front and rear adjustable input sensitivity controls
* Adjustable 0 – 15 dB Twin "T" 45Hz bass boost
* Muting circuitry for soft turn-on and turn-off
* Dual continuously variable 12 dB / octave high- or low-pass crossovers
* Advanced overload and thermal protection circuitry
* Silver high-current power and speakers terminals
* Silver RCA level inputs
* Auxiliary outputs route full range signals
* Optional RMD Remote Monitoring Display port
* Optional Neon Inserts
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 50W x 4 @ 14.4V
* THD at 4-Ohm RMS Power: n/a
* Bridged RMS Power @ 4 Ohms: 150W x 2 @ 14.4V
* Speaker Level Inputs: No
* Preamp Outputs: Yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 15 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >100 dB
* Fuse Rating: 2 x 20 amps
ummagawd@gmail.com
SPECS
Features:
