Directed 5CH Amp 800Watts
This is a used but in great working condition 5 ch amp (front, rear, and sub). I bought this to be used with my 5.1 surround sound setup.... however I need a seperate RCA input for the sub channel.... and since this one is so "high-tech" it actually doesn't have one. It utilizes the signals from either the front or rear input signals and filters the low frequency for the sub channel input. It still has seperate gain controls for sub, front, rear, as well as variable cross-overs for each channel. Its one of the best rated multi-channel amps out there.
Using this amp would save you on some wiring as an RCA for the sub isn't needed.
180 shipped.
With its complimentary bipolar output design and high speed MOSFET switching power supply, the Directed 650 five channel amplifier will make your subwoofers pound and your mids and highs sing! The Directed 650 is ideal for powering a complete sound system and features a continuously variable (from 50-500 Hz) 12 dB/octave 2-way crossover and a switchable 8 dB bass EQ function which will give that added bass emphasis that your system needs. The variable input sensitivity accepts up to 8 volt input, making it compatible with any source unit. Other goodies include a rugged one-piece extruded heat sink, nylon mounting feet, and gold-plated wire terminals and RCA connectors. Features full thermal, DC offset, reverse polarity and short circuit protection.
Multi-Channel Amp Specifications
* Amplifier Type: Multi-Channel
* RMS Power @ 4 Ohms: 50W x 4 + 250W x 1
* THD at 4-Ohm RMS Power: <0.08%
* Bridged RMS Power @ 4 Ohms: 150W x 2 + 350W x 1
* Speaker Level Inputs: No
* Preamp Outputs: No
* Built-In Crossovers: HP/LP
* Bass Boost: 8 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >95 dB
* Fuse Rating: 60 amps
180 shipped.
* Bass Boost: 8 dB
PVlexus
12-26-07 12:49 PM
istundra
11-06-07 02:29 PM
Lex*Toy
04-10-06 03:54 PM
