MMATS pro audio sub/ box/ amp combo for the GS
I am selling a MMats sub, sub amp, and box for the GS. If you dont know about MMats, do some research and you will see that they are amongst the best in quality and performance. I bought my GS from the owner of MMatsPro Audio out of Florida, so you know he matched this equipment up correctly. The box and sub came out of the car and are gently used, the amp is brand new in the box. When I bought the car he gave me their new model year amps to go with it. The box is built to fire up through the factory sub hole, and it takes up very little room.....you can barely tell that their is an aftermarket sub int he car from inside the trunk. The box holds a 10" MMats sub, and it is ported with two port tubes. The sound out of this 10" in the custom box is unbelievable....it sounds better than my two JL's that I had in my old GS. The amp is a 700 watt sub amp that is matched perfectly to the sub.
This is the perfect set up for those wanting great bass and sound quality without taking up room in the trunk. This is roughly $1000 woth of equipment, I am selling for $500.
Amp pic......model number is 1000.1
![](https://www.clublexus.com/gallery/data/500/medium/DSC002261.JPG)
Pic of box in the car, as you can see it sits on the shelf up against the back ot the rear seat....it fires up through the factory sub hole.
![](https://www.clublexus.com/gallery/data/500/medium/DSC00172.JPG)
PIc of the box out of the car.....obviously the uncarpeted areas are not seen when its installed, it sits against the rear seat......the foam looking pieces you see on the top of the box are pieces fo sound dampening material. They have those pieces to stop vibration into the rear deck...which there was none of at all. Notice the twin ports.......
Good question.......I went back and forth on selling it for awhile, and Im still hoping that Im making the right decision. The system in the car sounds incredible, but I need more of a show appeal for what I have going on wih the rest of the car. I bought an entire trunk set up from another CL member that uses a JL 10W7 with a custom enclosure, fiberglass amp rack, etc, etc..... The decision to change was 100% cosmetic!
Pics will be up today
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
actually mmats is very good, so i'll vouch for you . but the one you shouldve got was the jugernaut, but they recently came out with the drednaut to replace it. but i still think the jugernaut is a better performer. i need 1200 minimum rms wattage on an amp to power it correctly. so your lucky you got the regular series set up. which dont get me wrong its good also
Mayur Patel
09-14-01 11:54 AM
