Percison Power PPI 10 in sealed box
This sub was only hooked up for a week. It is so new it hurts to sell. I have decied to go another way. It is a PC-102 IN a sealed box. The box is also a week old. No rips or tears in the carpet. This sub will give you much improvement over the factory sub but just was not enough for me. If you are looking for more bass without disturbing the peace this is a perfect sub for you. The box is one cubic foot. If you have any questions just ask your time will not be wasted.
$55 + shipping
Product Details
Elements 1-Way
Function Subwoofer
Size 10"
Nominal Power Handling 250 Watt
Technical Features
Peak Power Handling 500 Watt
Frequency Response 45 Hz - 2.5 kHz
Sensitivity 83 dB
Impedance 4 ohm (Dual Coil)
Components
Woofer Material Poly / Plastic
Surround Material Foam
Mounting
Enclosure Non-Enclosed
Top Mounting Depth 5.5 In.
Mounting Diameter / Length 9.7 In.
Miscellaneous
MPN pc102
Product ID 21761710
PPI says: PowerClass subwoofers offer many of the same state of the art features as the flagship DCX product, but with more modest power handling and price targets. The heavy gauge steel baskets are tooled to reflect the same cutting-edge industrial design as DCX, while supporting very good excursion driven by less massive conventional motor assemblies. PowerClass subs use the same, ultra-rigid foamed polypropylene cone technology, a good match for the DCX coaxial or component speakers. Their power handling limit is a very strong 500 watts peak, for use in systems with the smaller PCX amplifier models. These subwoofers offer a strong combination of competition-grade performance and good looks, making them a good choice for most mobile audio enthusiasts.
$55 + shipping
Product Details
Elements 1-Way
Function Subwoofer
Size 10"
Technical Features
Sensitivity 83 dB
Components
Mounting
Miscellaneous
MPN pc102
Product ID 21761710
I think you would have to make a install plate. if i am right the hole is bigger then ten. but it should not be too hard. i also would have no use for the box besides firewood so i will still like to get 80 for it. i paid more then that for the sub. so i am already taking a big hit so the box is more or less free.
sjpobox
06-14-07 06:51 AM
Lvangundy
46
12-09-02 11:08 PM
billy boi
10-23-02 05:01 AM
