FS: 10" Kicker sub woofer and Baja Amplifier
I have a 10" kicker subwoofer and Baja Amplifier that I used in my 2000 GS and it sounded great. Sold the car so don't need this stuff any more.
10" Kicker sub info (note the warranty info):
The Comp (that's short for "competition") started the legend of furious Kicker sound, and its latest version — the Kicker Comp 05C104 10" sub — is a sight to see and hear. You'll thrill to sonic technology that'll rattle any teeth while still leaving a few bucks in your pocketbook.
A rigid polymineral cone with double-stitched, ribbed foam surround stands up to the most pounding of low tones while delivering them with great precision. The heavy-duty steel basket provides a rock-solid housing for the cone, while the famous Kicker Inverted Structural Dome holds the line on unwanted flexing. Perimeter venting helps to dissipate heat quickly for top performance.
And you'll appreciate the revamped cosmetics with a pitch-black cone and the striking basket design with its logo trim ring. Pick up an optional grille (click the "Accessories" tab) for an even fiercer look! This Kicker Comp 10" also works in free-air applications.
Details:
» 10" 4-ohm subwoofer
» polymineral cone with double-stitched foam surround
» high-strength steel basket
» frequency response: 30-500
» power handling: 50-150 watts RMS
» peak power: 300 watts
» sensitivity: 87.3 dB
» mounting depth: 4-13/16"
» spring-loaded nickel-plated terminals
» sealed box volume 1.0-2.4 cu. ft.
» ported box volume 1.25-1.75
» works in free-air applications
» Recommended Q-Logic Box Type: 2, 3
» warranty: 1 year (good through 4/19/06)
Baja amplier info (note warranty info):
Profile's Baja amplifiers combine quality design and features into an economical package that puts power and control at your command.
The Baja HA700M mono subwoofer amp is a great choice when you're looking to pound out the bass. With 200 watts RMS, there's plenty of juice on tap to power most single 4-ohm subs. Read more
Details:
» mono subwoofer car amplifier
» 200 watts RMS x 1 at 4 ohms (350 watts x 1 at 2 ohms)
» variable low-pass filter (50-250 Hz at 12 dB per octave)
» selectable bass boost (0/6/12 dB at 45 Hz)
» variable subsonic filter (20-50 Hz at 12 dB per octave)
» variable phase control (0-180 degrees)
» MOSFET power supply and output stage
» preamp- and speaker-level inputs
» preamp-level outputs
» fuse rating: 40A x 1
» 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 14"W x 2-1/4"H x 9-11/16"D
» warranty: 2 years (good through 4/19/07)
Price on subwoofer: $50
Price on AMP: $70
Price for both: $110. Shipping is additional.
Pictures available on request. Please PM your email address.
Details:
Details:
Price on AMP: $70
MrHorse
03-16-02 02:35 PM
