Alpine Type-X 2-Way Component Speaker Set SPX-177R
Alpine Type-X Component Speaker Set SPX-177R Brand New In Box!!! The MSRP on this is $450.00!!! Price is set at $260, Shipping is $25 (Shipping is waived if picked up locally; Located in SoCal)
![](http://img.photobucket.com/albums/v165/xknowonex/ALPINE-SPX-F177R.jpg)
Personally, these are one of the cleanest sounding sets out there for the money. It sounds just as good if not better than some sets that costs hundreds more.
The Type-X speaker is the perfect choice for a high-end multi-channel sound system. These ultra-high performance component speakers have high power capabilities and long mid-bass excursion for more bass. What's really great about this speaker is that no matter where in the vehicle they're located, you get the maximum effect of it's quality. That's because they can be easily tuned for optimum performance using the Advanced Phase Correction and Off-Axis Adjustment functions built in the crossover network.
As you look at each of the components you will see why our focused efforts have brought forth the finest sounding speakers possible for the mobile environment.
Crossover
3-Way/Dual Midbass Ready
Bi-Amp/Bi-Wire Capable
Gold Plated Terminals and Connection Jumpers
Integrated Level /Axis Adjustment
Phase Coherent Design
Tweeter Protection Circuit
Ultra-High Grade Passive Components (Metallized Poly Capacitors, Heavy Gauge Air core Inductors, Low Tolerance eatsink Resistors, OFC Circuit Board Traces)
General-Speakers
Bass Engine Ready
Bi-Wire Input and selectable Tweeter Attenuation
On/Off Axis Compensation
Ultra High Quality 2-Way Crossover
Tweeter
19mm Voice Coil, Copper Clad Aluminum Wire on Aluminum Bobbin
32mm (1") Ring Radiator Diaphragm with Wave Guide
Low Distortion Motor Structure with High Grade Neodymium Magnets and Copper Shorting Cap
Periphery Venting System into Cast Aluminum Tuned Chamber with Integrated Heatsink
Twist Lock Installation Ring with Compact Swivel System (Swivel-Flush, Swivel-Surface, Semi-Flush Angle Tweeter Mounting)
Woofer
4-Layer Copper Clad Aluminum Wire on Glass Fiber Bobbin
Airflow Optimized Dual-Flare Pole Vent
Braided Low-DCR Tinsel Leads
Custom Cast Aluminum Frame
FEA Optimized Motor Structure with CRC/T-Drive Geometry
High Grade Strontium Ferrite Magnet
High Quality Synthetic Black Spider
Integrated spider Landing & Vented Heat Transfer Plate
Low Resonance Multi-Roll Surround (LRMS)
Non-Resonant Suspension Coupling (NRSC) with Reinforced Edge
OEM Adapter
Semi-Flush Grille
Single Voice Coil Design
Snap Fit Mounting System
Wood Fiber Cone & Phase Integrated Dust Cap
General-Speakers
Frequency Response : 35 - 60kHz
Impedance (Nominal) : 4 ohms
Mounting Depth (Tweeter) : 14mm / 0.6"
Mounting Depth (Woofer) : 70.8mm / 2.8"
Mounting Diameter (Tweeter) : 35mm / 1.4"
Mounting Diameter (Woofer) : 132mm / 5.2"
Net Weight : 5 kg
Tweeter Thiel Small Parameters
Complience (Cms) : 0.14 mm/N
Cone Area (Sd) : 4.55 cm
D.C.Coil Resistance (Re) : 2.80 ohm
Electrical Q (Qes) : 0.88
Force Factor (Bl) : 1.6 T-m
Free Air Resonance (Fs) : 950 Hz
Frequency Response : 600 - 60kHz
Inductance (Le) : 0.1 mH
Mechanical Q (Qms) : 1.3
Moving Mass (Mms) : 0.2 g
Sensitivity : 86dB
Woofer Thiel Small Parameters
Coil Height (Hvc) : 11.3 mm
Compliance (Cms) : 1.22 mm/N
Cone Area (Sd) : 132 cm
D.C.Coil Resistance (Re) : 3.2 ohm
Electrical Q (Qes) : 0.50
Equivalent Suspension Stiffness (Vas) : 30 Liters
Force Factor (Bl) : 4.3 T-m
Free Air Resonance (Fs) : 43 Hz
Frequency Response : 45 - 15kHz
Gap Height (Hag) : 5 mm
Inductance (Le) : 0.80 mH
Linear Excursion (X Max) : 3.15 mm
Mechanical Excursion (Peak-to-Peak) : 16 mm
Mechanical Q (Qms) : 4.90
Moving Mass (Mms) : 11.2 g
Sensitivity : 90dB
Total Loudspeaker Q (Qts) : 0.45
Key Features
Crossover
General-Speakers
Bass Engine Ready
Tweeter
Woofer
OEM Adapter
Semi-Flush Grille
Specs:
General-Speakers
Net Weight : 5 kg
Sensitivity : 86dB
Sensitivity : 90dB
FireCode
SC400 / 300 Classifieds
07-24-10 01:54 PM
howiedoit
08-01-04 10:18 PM
