FS: **audiobahn system** (subs,amp,faradcap,linedriver,etc)
have to repost:
A2200HCX amplifier
200 watts x 2 @ 4 ohms stereo & 400 watts x 2 @ 2 ohms stereo & 600 watts x 2 @ 1 ohm stereo & 1600 watts x 1 @ 1 ohms mono & Dimensions: 3.5"(H) x 12"(W) x 24"(D) , High Current Circuitry & PWM MOSFET Power Supply & Double Sided Glass Epoxy Circuit Board & S/N Ratio: >100dB & Frequency Response: 10Hz 40KHz (+/- 1dB) & Remote Bass Control With Blue Backlight ***** & Variable 24dB High-pass Crossover: 90Hz 750Hz & Variable 24dB Lo-pass Crossover: 30Hz 120Hz & Variable Subsonic Filter: 20Hz to 45Hz & Variable Bass Boost: 0 18dB & Variable Bass Boost Frequency: 40Hz 100Hz & RCA Throughput Connections 4-way Protection Circuitry: Thermal, Short Circuit, Overload, and DC Offset & Dual Cooling Fans & VU Meters Indicating Output Response & Cobalt Blue Illumination & High Gloss 14K Gold and Chrome Plated Finish & Nickel Plated Block Terminals
Alum12x subwoofers
Rec. Sealed Box Dims: 0.75 - 1.50 cu.ft.
Rec. Ported Box Dims: 1.73 cu.ft.
Free Air Usage: not recommended
Sensitivity: 96.4 dB
Frequency Response: 18-500 Hz
Recommended RMS Power: 1000W
ALD30X 2-Channel High Performance Line Driver
Frequency Response: 20 Hz to 30 kHz | S/N: >100dB | THD: 0.005% | Maximum Output: 8 Volts | PWM Power Supply | Low Level Inputs | Low Level Outputs | Variable Output Adjustments | Blue LED Digital Volt Meter | Blue Aluminated Function ***** | Blue LED Indicator Light | Chrome Plated Case | Chrome Protective Handles | Clear Acrylic Protective Cover
-Audiobahn 1Farad Capacitor
-RCA converter
A2200HCX amplifier
Alum12x subwoofers
-RCA converter
O. L. T.
07-28-10 02:33 AM
shern
04-30-10 12:05 PM
