2 DLS A6 *ULTIMATE* series 1200w Mono Amps
2 - DLS A6 *ULTIMATE* series 1200w mono amps
Anyone that knows car audio knows these are some bad *** amps. A good set of 15's with one amp on each is sure to make some noise
ULTIMATE series A6. A 1 ohm stable monoblock that´s perfect for SPL. Extremely powerful power supply. The output power in 4 ohms are 500 thrue RMS watts. A cooling fan is built in but the amplifier also provides a built-in fan control for external cooling fan.
Built-in, variable 50-125 Hz low-pass filter for subwoofers plus a 25 Hz subsonic filter with an 18 dB/octave slope. Dual power terminals where you can connect dual power feeds or a DLS Power Cap. Extra features are a phase control variable 0-180 degrees continiously.
A remote sub level control is included. Adjust the sub level and phase from the front seat!
RMS output per channel at 13,8 volts, < 0,1% distortion.
Mode : AB
Number of channels : 1 ( for subwoofer use )
Output power in 4 ohm : 500 W
Output power in 2 ohm : 870 W
Output power in 1 ohm : 1200 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filters : Lowpass: 50-125 Hz. Subsonic: 25 Hz
Terminal for external cooling fan : Yes
Dual DC-inputs : Yes
Phase control 0-180 degrees : Yes
Remote sub level control with phase shift : Yes
Current draw, idle : 0,6 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight : 6,2 kg ( 13,67 lb)
Or visit their site here: http://www.dls.se/english/fstark/a6n.htm
I have two of these amps here and would like to sell them together hence the discount. RETAIL PRICE IS $625 EACH...... 1 for $250 or both for $400 email me if interested rather than posting in the thread please xdsmx@aol.com thanks
![](http://www.dls.se/fstark/a6.jpg)
Mode : AB
jishan
04-10-08 09:05 PM
Damned04
06-25-06 11:32 PM
