FS: Panasonic CX-DH801U 8 Disc DVD Changer (NEW)
ALL CONTENTS CONFIRMED TO BE COMPLETE!
* This item was opened to test functionality and to confirm contents *
* ITEM SOLD AS- IS *
$220.00 + $25.00 S/H -- Will consider trades for 2GS or 2IS. Make Offer!
Factory Navigation? With the proper module, you may add this changer to play DVD's from your OEM Navigation screen.
Key Item Features:
* RCA Video / Audio OUTPUT - You may connect this changer to any monitor! Even your home TV!
* 8 Disc DVD Video Changer
* Infrared Remote Sensor Eye - Conceal this changer in your car at any location and route the remote eye to the front for controls!
* Infrared Remote
* Panasonic Head unit compatibility - utilizes DIN Plug - Check with www.panasonic.com to view compatibility list.
Items Features from Pansonic Website:
* Panasonic 8 Disc DVD Changer CX-DH801U
o Plays a wide range of media DVD/SVCD/DVCD/VCD1.0, 1.1, 2.0/MP3 & CD/CD-R/CD-RW.
o 8-DVD autochanger
o Full function remote control with IR extender
o Stereo audio and twin video output
o Multi position fitting brackets
o Anti shock mechanism
o Power noise filter
o Standard RGB video cables - can be connected to any brand of screen
o Analog and digital output
o Includes:
+ Remote control unit
+ Disc magazine
+ Remote Eye
+ Mounting brackets
+ RGB cables
+ 12V supply
Fits Almost Anywhere
The CX-DH801U is extremely compact and will fit in many glove compartments or even under a seat, so you're not limited to using the trunk for installation as is the case with some less-compact CD changers. Installation is further simplified since you can mount it upright, horizontally, or at three more selectable angles.
Reads Single and Dual Layer DVDs
The laser pickup in this DVD/CD Changer adjusts its elevation to accurately read single layer and dual layer type discs.
96kHz/24-bit Digital-to-Analog Converter for High-Precision Sound
The CX-DH801U boasts a high-precision 96kHz/24-bit D/A converter. According to digital audio theory, high frequency reproduction is limited to half the sampling frequency used for recording. Therefore, the frequency response of linear PCM audio in some DVD Videos can potentially extend all the way up to 48kHz (half of 96kHz). While humans cannot hear sounds above 20kHz, very high frequency overtones may influence how we hear the details in audible sounds, such as the crash of cymbals.
Anti-Shock Floating Mechanism for Less Skipping
Thanks to this DVD/CD changer's floating suspension, there's no need to worry about annoying disc skipping. The critical laser pickup and disc loading mechanism is isolated in a floating suspension, with two suspension coils and four rubber-plus-silicone dampers helping to absorb external vibrations.
Skip Over Empty Slots with Learning Skip
No more unnecessary pauses when you've got empty disc trays. Instead of trying to access a non-existent disc, this CD changer learns which slots are empty and will automatically skip over them, accessing only the CDs that are actually loaded.
Hours of Uninterrupted Movies and Music
This CD changer lets you load up to 8 DVDs and/or CDs so you can enjoy hours of uninterrupted movies and/or music.
Pictures:
Payments: Paypal, Cashiers Checks, Money Orders
Shipping: $25.00 via UPS Ground
NO INTERNATIONAL SHIPPING! UNITED STATES ONLY!
Key Item Features:
* Infrared Remote
o 8-DVD autochanger
o Includes:
+ Disc magazine
+ Remote Eye
+ Mounting brackets
+ RGB cables
+ 12V supply
Pictures:
Do you know if this is compatible with the following head unit?
http://www.crutchfield.com/S-nJ3d7jK...=133VD6503#Tab
