Alpine Type X sub & Box for 1998-01 GS300 / GS400
Brand new type X sub with a custom 4th Order box built to 2nd Gen. GS300 / GS400 specs. The port Fires thru the stock subwoofer location...Hits hard as @#$&!! while leaving plenty of trunk space.
Comes with original packaging and documentation for the sub...The box simply kicks ***.
Reviews: http://www.crutchfield.com/S-CcHKBYB...tab=review#Tab
Specs on Sub:
Bass alert — Alpine's Type-X subwoofers bring the ultimate combination of power and performance to your sound system. Engineered with high output in mind, Alpine's top-of-the-line subs handle a mind-blowing 3,000 watts of peak power, while still reproducing the tight, low frequency detail that means great bass.
The SWX-1042D 10" subwoofer provides full bass by squeezing every last millimeter of excursion from the carbon fiber/aluminum honeycomb cone, thanks to its high-roll Santoprene rubber surround. A patent-pending basket design uses air channels in the frame to force out hot air and miminize distortion. It all adds up to huge output and terrific sound quality.
The reinforced tinsel lead design places both terminals on the same side, providing easier installation and wiring. The unique terminals easily accept high-gauge speaker wire. The SWX-1042D is designed for use in sealed or vented enclosures.
Note: If you are wiring this DVC sub for lower impedance, make sure that your amp is compatible. Most car amplifiers are stable down to 2 ohms in standard mode, or 4 ohms in bridged operation.
Details:
10" subwoofer with dual 4-ohm voice coils
cast aluminum frame
frequency response: 24-200 Hz
power range: 500-1,000 watts RMS (500 watts per coil)
peak power handling: 3,000 watts
sensitivity: 81 dB
top-mount depth: 8-5/8"
sealed box volume: 0.5-1.0 cubic feet
ported box volume: 0.8-1.5 cubic feet
I'll get actual pix of the box later today.
$300 Seattle, Wa
Would rather sell locally....
Specs on Sub:
Details:
cast aluminum frame
sensitivity: 81 dB
$300 Seattle, Wa
TTurboPimp
11-16-05 04:59 PM
Rich27
02-24-05 09:07 PM
