FS- NEW 18 inch sub. Elemental Designs
Ok guys... As much as I wanted to do the dual 18 inch setup, I'm going to go single so I'm selling out one of my 18's.
Its an elemental Designs sub, it works fine. I have tested it already and it plays great. I never used it aside from just testing it.
Im asking 200 + shipping. The sub weighs about 42 lbs. It weighs 77 lbs in the shipping crate. Im also including the MDF ring for mounting ($25) for FREE.
Its a dual voice coil sub. Its Dual 4 ohm coils.
This is a great sub for any Hatch, SUV or Truck
Here are the specs and pictures.
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26 Hz
Re: 3.5
Vas: 228 L
Mms: 307 g
Bl: 22.1 T*m
SPL: 90.5 dB
Sd: 1200 cm^2
Xmax: 22 mm
Voice Coil: 62.5 mm
Magnet Width: 8.200"
Cutout Diameter: 16.375"
Mounting Depth: 9.625"
Weight: 42 lb
Total Height: 10.600"
Displacement: .10 ft^3
Outside Diameter: 18.375"
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26 Hz
Re: 3.5
Vas: 228 L
Mms: 307 g
Bl: 22.1 T*m
SPL: 90.5 dB
Sd: 1200 cm^2
Xmax: 22 mm
Voice Coil: 62.5 mm
Weight: 42 lb
mdgrwl
06-24-11 07:33 PM
RawkusX187
05-06-10 12:41 PM
Kaine
06-08-05 01:53 AM
