CarPC, Complete plugNplay Kit w\7" Indash Enclosure
Old 07-02-07, 08:41 AM
CaMsGS3
CaMsGS3's Avatar
Default CarPC, Complete plugNplay Kit w\7" Indash Enclosure
Well as some of you already know, my GS went back and im almost done selling all my parts. I had this on my car for almost 3yrs. Installed it myself, took about 11hrs total(7hrs one day, 4hrs the next) to install...the hardest part was running the cables and soldering each speaker wire to the metra kit, plus getting all my wire diagrams ready on to whats going where, what factory wires do what, etc..
This System is meant to have the PC located in the stock CD changer location, AMP is located in the trunk..you can change it around, but then you would have to rerun all the connections urself, like i had to... all the runs are perfect size with extra slack..its just how i had it in my car..hence plugNplay kit....dam i wish i had something like this when i was installing mine, but anyways
This is whats included:
PC Specs:
-VIA EPIA M10000 (17cmx17cm)
-1Gig of Ram
-spare 256MB of ram
-120Gig notebook HD
-c134 case, (about the size of a cereal box)
-Panasonic DVD slot loading drive (never used, just throwing it in)
-Carnetix Power startup\shutdown controller(CNX-P1260), this is already wired up..ALL wiring is soldered on, even when making extensions
-7" Xenarc Touchscreen, with video inputs(can add a backup camera)
-Custom plug and play enclosure, matches 100% to the AC unit..screen is already built into it...just plug in the VGA and power cord...witch that is already wired up to the startup\down controller (J2 Plugs, look at diagram below)
-25 Foot USB extension
-USB GPS unit (place it in the rear)
-Speaker wire already soldered, just run it to the amp, also each wire is labeled to whats going where(Driver Front speaker, etc)so when u get the run to the AMP you will know
-25 Foot RCA's (bundled with the speaker wire, for the run to the trunk, perfect lenght)
-4 Port USB Hub (one front USB on the front of the MB is not workin, due to it fitting in the glovebox)
-2Gig Mini portable Hardrive, (to transfer your MP3's to your car)
-House AC adaptor,w\MB plug\
-Jenson streering wheel remote...(you just need to get a USB-UIRT, its $50 bucks) I need mine for my HTPC - the config file will work once you plug in the uirt..so again no setup required
-5CH AMP, with RCA inputs (required with a carPC setup)
$600 + shipping for everything..
CaMsGS3 is offline
Old 07-02-07, 08:42 AM
CaMsGS3
CaMsGS3's Avatar
So when I removed this kit 2 weeks(took me 1/2hr) i left all my cable runs, startup\shutdown controller, metra kits all intacted..already wired and ready to install in another GS...you would need to ONLY run 4 wires urself,
First take a look at my Wire Diagram that i made when i was in the planning stages to get a better over all look,
The CNX-P1260 will be located to the right on the PC, its where the factory AMP was located
Wires you will have to run:
[1] 12v - from the battery to the PC(startup\shutdown controller,CNX-P1260) + ground
[2] 12v - from the battery to the AMP + ground
[3] Ground the startup\shutdown controller,CNX-P1260
[4] Dlyon (blue) Wire to the AMP - this is so you dont here a "thump"(the speakers poppin) when u start you car
More info, so you guys get a better idea :
look at [J1] - ACC wire is already plugged into a metra kits(these kits hoook up to the factory wiring, and u splice from there, rather then using the factory wiring)
[J1] the red line is your 12v that you will have to run to your battery, and also your ground...i used a spot right above the placement of the carnetix
[J2] - 12v for the screen and MB are already connected, just plug in to device..
[J2] - (not in pic) is a green and black wire, these are also already connected, these plug into the Jumpers spot on your MB
the green(speaker wire) & gray(RCA) lines are..this was the longest part of the install..
BUT for u all speaker lines are soldered onto the metra kits...so all you do is plug in the metra kit to the factory harness, then run these to the back to your AMP
CaMsGS3 is offline
Old 07-02-07, 08:43 AM
CaMsGS3
CaMsGS3's Avatar
Here are some PICS, 1st are some of the indash enclosure w\7" touchscreen,
Attached Thumbnails CarPC, Complete plugNplay Kit w" Indash Enclosure-screen-upside-down.jpg
CaMsGS3 is offline
Old 07-02-07, 08:44 AM
CaMsGS3
CaMsGS3's Avatar
Here is the speaker wire and RCA runs that will go to the trunk
Close up
Here is the metra plugs connecting to the speaker wire...these metra plugs plug right in to the factory wire harness...all these are already soldered on..and labled
CaMsGS3 is offline
CaMsGS3
CaMsGS3's Avatar
These pics are showing the CNX-P1260, this is the J1 plug (refer to my wire diagram above)
J2 plug again all wires are already soldered, just plug in
CaMsGS3 is offline
Old 07-04-07, 09:08 AM
blkgs4wnav
blkgs4wnav's Avatar
cam do you have any pics of this installed in your car
blkgs4wnav is offline
Old 07-04-07, 10:12 AM
CaMsGS3
CaMsGS3's Avatar
im trying to located some, i think i may have.... I meant to take some nice pics right before i removed this system....but when i signed the papers for my new truck..i rushed home to remove it and totally forgot to take pics..i remembered when my car looked like this...
CaMsGS3 is offline
Old 07-04-07, 10:14 AM
CaMsGS3
CaMsGS3's Avatar
Pics of the PC
On this pic, you see the green sound connection, the piece is cracked BUT it has no effect on the system, i used it like this for 2yrs
CaMsGS3 is offline
Old 07-05-07, 07:29 PM
Joe C
Joe C's Avatar
That is a great looking setup!
You've got a PM...
Joe C is offline
Old 07-05-07, 07:30 PM
blkgs4wnav
blkgs4wnav's Avatar
is the breitling included
Old 07-05-07, 08:08 PM
CaMsGS3
CaMsGS3's Avatar
HA, yea sure just add another $3500 on to the price
I realized after they were loaded on my PC, that i forgot to move the watch..didnt feel like retaking the pics
CaMsGS3 is offline
Old 07-11-07, 11:46 AM
CaMsGS3
CaMsGS3's Avatar
Bump......
CaMsGS3 is offline
Old 07-11-07, 04:05 PM
trix
trix's Avatar
i'll trade my clarion flip out for your carpc.... just throwing it out there
trix is offline
Old 07-11-07, 06:02 PM
GSoup
GSoup's Avatar
Hey whats goin on... Did you pick up your new ride?
If you ever decide to part out the screen let me know. you can consider it sold
Either way GL on the sale.
Bump for a good seller
GSoup is offline
Old 07-11-07, 10:57 PM
blacklexT
Bluelex's Brother
blacklexT's Avatar
is this touch screen and is it still for sale if so pm me cash at hand
blacklexT is offline
Quick Reply: CarPC, Complete plugNplay Kit w\7" Indash Enclosure
