12" Kickers in Enclosure with Rockford Fosgate AMP MD/VA
![](http://img338.imageshack.us/img338/8858/1000490zt7.jpg)
![](http://img338.imageshack.us/img338/7154/1000495tl5.jpg)
Enclousure info:
Sturdy 3/4" medium-density fiberboard ensures long-lasting performance from the enclosure. You'll get hassle-free connection to your amp with the single set of speaker terminals, and the 2-ohm impedance draws more power out of your mono sub amplifier.
Details:
» ported hatchback-style enclosure with two 12" CompVR subwoofers
» 3/4" medium density fiberboard construction covered with gray carpet
» 2-ohm total impedance
» power handling: 50-600 watts RMS (1,200 watts peak power)
» frequency response: 25-500 Hz
» sensitivity: 98 dB
» 32-3/4"W x 16-1/4"H x 17-1/2"D1 x 14-1/4"D2
Slight damage to the enclousure one corner has paint on it:
![](http://img527.imageshack.us/img527/2300/1000492ke0.jpg)
![](http://img527.imageshack.us/img527/4266/1000494ld1.jpg)
__________________________
Amp: Rockford Fosgate P4002 2 Channel AB Amplifier
Outputs: 1 Pair - Bridged Watts: 400 x 1 - With Built-in Crossover - With Bass Boost - 80 db Signal to Noise Ratio
Manufacturer Sku: P4002
Brand: Rockford Fosgate
Amplifier Class: (what's this?) AB
Number of Channels: 2
Min Frequency Response: (what's this?) 20 Hz
Max Frequency Response: (what's this?) 20 KHz
Bridgeable: (what's this?) Bridgeable
Protection LED: With Protection LED
Power LED: With Power LED
Power supply topology: (what's this?) MOSFET
Input Voltage: 14.4 volts
Signal to Noise Ratio: (what's this?) 80 db
Warranty: 1 Year
Features
Bass Boost: (what's this?) With Bass Boost
Fuse Rating: (what's this?) 2x30 AMPS
Wire gauge: 4
Remote Control: (what's this?) With Remote Control
Output Power
Preamp Outputs: (what's this?) 1 Pair
Bridged Power (Watts x Channels): (what's this?) 400 x 1
Power at 2 Ohms (Watts x Channels): (what's this?) 200 x 2
RMS Power Output (Watts x Channels): (what's this?) 100 x 2
Minimum Impedance Bridged: (what's this?) 4 Ohms
Minimum Impedance Unbridged: (what's this?) 2 Ohms
Tri-Mode Capable: (what's this?) Tri-Mode Capable
Crossover
Built-in Crossover: (what's this?) With Built-in Crossover
High-Pass Crossover Min Frequency: (what's this?) 40 Hz
High-Pass Crossover Max Frequency: (what's this?) 400 Hz
Low-Pass Crossover Min Frequency: (what's this?) 40 Hz
Low-Pass Crossover Max Frequency: (what's this?) 400 Hz
High-Pass Slope (dB/octave): (what's this?) 12 db
Low-Pass Slope (dB/octave): (what's this?) 12 db
Dimensions
Height: 2.4 in
Depth: 17.7 in
Width: 11 in
Prices:
150$ for amp alone
300$ Subs in enclosure
400$ for the package (subs and amp)
Located: Maryland/Virginia/DC Area
Contact:
Email: denniswang07@yahoo.com
loveslexus
11-14-13 04:07 PM
lowKut
03-03-08 04:04 PM
kokopuffs4
03-08-07 02:56 PM
