Clarion DPX1500 & Kicker KX 2500.1 AMPS
*Clarion DPX 1500
1500 Watts of Maximum Music Power
800W × 1 Into 4 Ohms, 20Hz-20kHz @ < 0.05%THD
1500W × 1 Into 1 or 2 Ohms, 20Hz-20kHz @ < 0.1%THD
Adjustable Subsonic Filter, 10-80Hz
Remote Control Included
Input Voltage Selector
Precise Frequency Selector
Variable Bass Boost; 0-15dB @ 30-125Hz
Adjustable -12db/Oct. Low Pass Crossover, 50-250Hz
Gold Plated Connectors; RCA/Speaker/Power
Speaker Level Input
Dimensions 21 1/4" × 12" × 2 7/8"
These are the last years model amps which were discontinued about 3 months ago. We've had them playing music nonstop @ .35 ohms with no issues putting out ~1800w on a 12v system. Capable of putting out 220+ watts @ 16v. They are far superior to the current model out. Retails for $599 on Clarions site but sells for around $400 around here. $275 each or 2 for $500. I have 2 left.......
Kicker kx2500.1
RMS Power Range : 1250-2500 Watts
Number Of Channels: 1
Maximum Power: 2500 Watts
Low Frequency response: 20 Hz
High Frequency Response: 200 Hz
Fan Cooling
Radically Advanced Chassis with Removable Chassis Shroud
Short Circuit, Over-Voltage, Reverse Polarity, Thermal (SORT) Protection
Efficient Class D Circuitry
Remote Bass Boost Control
KickBass 0-18 dB Variable Bass Boost at 40 Hz
12 dB / Octave Low-Pass Crossover
Defeatable 12 dB / Octave 25Hz Subsonic Filter
Variable Crossover Frequency from 50-200 Hz
PreAmp Signal Transfer (PAST) Output RCA Jack
Delayed Turn-Off Logic Circuit
Soft Start Turn-On Circuit for Reduced Startup Load
RMS Power: 1250W x 1 @ 4 ohms
RMS Power: 2500W x 1 @ 2 ohms
Speaker Level Inputs
Preamp Outputs
Built-In Crossovers
Bass Boost: 0 - 18 dB
Frequency Response: 20-200 Hz
MSRP is $1499 but they sell for around $800. Selling mine for $550 each or 2 for $1000. I have 3 of these...
Email me @xdsmx@aol.com
Speaker Level Input
Kicker kx2500.1
Fan Cooling
Preamp Outputs
Built-In Crossovers
Rancher
04-25-11 05:17 AM
95lexsc300
08-29-10 11:23 PM
jishan
04-10-08 09:05 PM
