Mb quart qsc 216 6.5
I am selling my beloved 6.5 MB QUART QSC component set.
The amplification used for this set was a JL 450/4
They are 1.5 years old, however they were in a car that has only had 3000 miles put on it in the last 2 years.
220.00 + shipping
![](http://i79.photobucket.com/albums/j156/jmaal13/P1110563.jpg)
Technical Specification
Sensitivity: 90 dB
RMS Power Range : 80-150 Watts
Peak Power Handling: 300 Watts
Frequency response: 35-32000 Hz
Diameter: 6.5 Inch
Features
2-way Component Speakers System
1" Titanium tweeter
6.5" Polypropylene woofer with special coat
Crossover
Crossover Frequency 2.400 Hz
Crossover Slope 12/12 dB/octave
Impedance: 4 ohms
A new variation of the WPC process used in QSD is applied here
Midrange with 37mm (1.5") voice coil is used - Former made of Kapton foil (a temperature resistant plastic) that can withstand extreme heat
Regardless of the wire size or type you can always connect to an MB QUART. Connection types include solder, screw-down, spade or bare wire.
Designed specifically for low-profile installations, these die cast aluminium baskets can be installed in factory locations with little or no modification. They are lightweight but extremely rigid.
BBalanced Temperature Technology is used throughout
Tweeter level can be adjusted in 2dB steps up to -6dB
A light bulb is incorporated into the crossover networks to extend the life of the tweeter by protecting it against overloading.
Tweeter with a 25 mm (1") titanium dome with a highly elastic butyl rubber surround
Here is a review:
http://www.caraudiomag.com/testrepor...ers/index.html
220.00 + shipping
Sensitivity: 90 dB
Diameter: 6.5 Inch
Features
1" Titanium tweeter
Crossover
Impedance: 4 ohms
Here is a review:
Please respond in post to the questions above. This will help everyone understand the product you are trying to sell a little bit more! Thanks!
Kuroikaze
05-09-11 10:01 AM
xknowonex
02-02-06 09:09 PM
