FS: Soundstream PCA2.360 2-Channel Amplifier
Old 11-25-08, 12:21 AM
nightlifex
nightlifex's Avatar
Default FS: Soundstream PCA2.360 2-Channel Amplifier
Technical Specification
RMS Power Range : 110-180 Watts
Number Of Channels: 2
Maximum Power: 360 Watts
Low Frequency response: 10 Hz
High Frequency Response: 30000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
No. OF CHANNELS: 2
OUTPUT (watts):RMS @ 4 Ohms 110x2
RMS @ 2 Ohms 180x2
RMS @ 4 Ohm Mono 360x1
T.H.D.: 0.02%
FREQ. RESPONSE (Hz): 10 - 30k
SIGNAL TO NOISE RATIO: >97dB
DAMPING FACTOR: >200
INPUT SENSITVITY: 0.5 - 4.0V
CROSOVER SLOPES: 12dB
CROSSOVER FREQUENCY: High-Pass(Hz) 50 - 600
Low-Pass(Hz) 50 - 150
SUBWOFFER EQ: 0 - 18dB 0
SUBWOOFER EQ FREQ. (Hz) : 40 - 120
DIMENSIONS (INCHES): 9.5x2.5x13.0
Fully regulated MOSFET power supplies
PWM circuitry
Tri-guard amplifier protection
IDI (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
Platinum RCA inputs and outputs
Line Outputs
Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
Continuously variable high and low-pass crossovers
Variable subwoofer equalizer
Phase inversion switch (0 - 180)
OEM floating ground input
Platinum 4-gauge power connectors
Tri-mode operation
Optional Remote Bass Control (EGA-RM)
$60 OBO
nightlifex is offline
Nigel-JDMParts
14
06-08-11 12:36 PM
97GSTAT
03-01-10 07:45 AM
Tony26
09-02-08 05:15 AM
Quick Reply: FS: Soundstream PCA2.360 2-Channel Amplifier
