Rockford Fosgate P1000-1bd mono subwoofer amp
Location: ~SIMPLY TUCKED~ scraping the mean streets of L.A.
![](http://i241.photobucket.com/albums/ff117/auto_addictions/used%20parts/IMG_1741.jpg)
![](http://i241.photobucket.com/albums/ff117/auto_addictions/used%20parts/IMG_1735.jpg)
this amp was used for about 4 months, it's a great amp, hits really hard i couldn't even turn it up all the way with my JL W7. i bought it about 10 months ago for $650, i want $325 picked up in socal or $350 shipped to lower 48 states
info taken from Rockford fosgate's website:
Rockford Fosgate continues to develop progressive sound technologies, aimed at producing a smaller amplifier with all the power and clarity you expect from a Punch amp.
The award-winning "Dynamic Thermal Management" 3-stage cooling system uses forced air to dissipate heat evenly across the amp and out through the heatsink for cooler internal components. This Class-BD amplifier combines the best features of traditional Class AB amplifiers with the efficiency of the Class D design for lower distortion and less power draw. Its smaller chassis gives you more installation options, without sacrificing wattage or audio quality. The P1000-1bd mono subwoofer amp dispenses 250 RMS watts at 4 ohms, or you can wire your subs for a 2- or 1-ohm load to achieve higher power output — up to 1,000 watts. You can tailor the sound with variable-frequency low-pass and subsonic filters, and use the onboard EQ to add some low-frequency punch to compensate for your car's acoustics. An optional wired remote control lets you tweak the sound from the front seat for quick adjustments while you're on the road.
Details:
* mono subwoofer amplifier
* 250 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
* 1,000 watts RMS x 1 at 1 ohm
* CEA-2006 compliant
* Dynamic Thermal Management cooling system
* variable low-pass filter filter (35-250 Hz, 12 dB/octave)
* selectable subsonic filter (28Hz, 12 dB/octave)
* variable bass boost (0-18 dB at 45 Hz)
* optional wired remote bass boost
* Class-BD amplifier design
* MOSFET power and output stages (uses TO-247 MOSFETs)
* preamp-level inputs
* preamp outputs
* 4-gauge power and ground leads and an 140-amp fuse recommended — wiring and hardware not included with amplifier
* no onboard fuses — when installing multiple amps in a system, an additional 140-amp in-line fuse between the distribution block and the amplifier is recommended
* 14-1/4"W x 2-1/4"H x 8-1/2"D
