FL Pioneer GM-7200M 800W Mono Channel Amplifier
for sale Pioneer GM-7200M 800W Mono Channel Amplifier in good conditions!!!!! $70 obo... just local pick up!
Technical Specification
RMS Power Range : 250-360 Watts
Number Of Channels: 1
Maximum Power: 800 Watts
Built In Crossovers: Yes
Channel Separation: Yes
Features
Mono channel capability @ 2 Ohm: 1 x 800W
Mono channel max power @ 4 Ohm: 1 x 500W
Continuous output power @ 2 Ohm: 1 x 360W
Continuous output power @ 4 Ohm:1 x 250W
Load impedance capability: 2 — 8 Ohm
Variable LPF( -12 dB/Oct): 40 - 240 Hz
High Voltage Input capability: 200 mV — 6.5 V
Channels: 1
Input level/gain control
Bass Boost: 50 Hz 0/6/9/12 dB (Remote)
RCA input terminals
Speaker Terminals: screw-type
Power / ground terminals: Large screw-type
LPF: 40 - 240Hz (Variable)
High voltage input capability: 400 mV - 6.5 V
Distortion: < 0.03 %
S/N ratio: > 100 dB
Max. current consumption (A/4ohms): 33
Chassis size (W x H x D): 300 x 31 x 336 mm
Unit weight: 3.9 kg
Features
Channels: 1
RCA input terminals
S/N ratio: > 100 dB
Unit weight: 3.9 kg
jishan
04-10-08 09:05 PM
