Phoenix Gold Amps
Phoenix Gold Titanium 600.2 - $555 shipped
ZX600ti Dynamic Power (IHF-202): 4 ohm Mono 600 x 1 2 ohm Per Ch. 300 x 2 4 ohm Per Ch. 150 x 2 2 Channel Power Amplifier Increased Power Dead Silent Turn [on/off] TAIM® Circuitry Variable Speed Fan for Reliable Cooling Better Stability - Ultra Low Loads (2 Ohms bridged) All New Titanium Finish! Superbrite™ Tri-LED Power On 24dB Crossover [HP/LP] with Aux Output Variable Crossover Range: 40 to 800Hz Dimensions: 16.0L x 9.8W x 2.25H Frequency Response +/-1dB, 20Hz to 20 kHZ Signal to Noise Ratio (A-weighted) 100dB Max Continuous Bridged Power @ 1% THD 600 watts x 1 into 4 ohms @ 14.4 Vdc Max Continuous Power per Channel @ 1% THD 300 watts x 2 into 2 ohms @ 14.4 Vdc Nominal Continuous Power per Channel @ 1 % THD 150 Watts x 2 into 4 ohms @ 14.4 Vdc IASCA/USAC Power Rating 75 Watts x 2 into 4 ohms @ 12.5 Vdc Minimum Load when Bridged 2 Ohms Minimum Load per Channel 1 Ohm Input Signal Voltage Range 0.2 volts to 6 volts Crossover Type Cont. Variable Linkwitz Riley HP,LP Crossover Slope 24 dB per octave Crossover Frequency Range 40-800Hz Auxilary Output Channels yes Auxilary Output Frequency Range 40-800 hZ Hi-level Input no Bass Boost 0- to +18dB @ 45 hZ Power Supply Voltage 10Vdc to 15.5Vdc Recommended Fuse 60 amp Dimensions, Chasis 15.00L x 9.00W x 2.25H Dimensions, Overall 16.00L x 10.00W x 2.25H
I also have the following:
Phoenix Gold Titanium 400.2 for $420 shipped
Phoenix Gold Titanium 500.4 for $560 shipped
![](http://www.chronic-systems.com/inventory/phoenix%20gold/2002/amplifiers/titanium600.2/tiampmodels-600.2_small.jpg)
jishan
04-10-08 09:05 PM
