KS FS: Precision Power DCX-730
Precision Power (PPI) DCX-730 Digital Signal Processor and it's BNIB
6 Channel RCA Input Jacks
6 Channel RCA Output Jacks @ 7.5V RMS Max
Output THD+N <.05%, 30KHz bandwidth
Input Topology PPI balanced differential
Signal to Noise Ratio >85dB A Weighted @ Max Out
Frequency Response 20-20KHz +/- 0.25 dB
Input Impedance 10K Ohms
Input Sensitivity 250 mV - 12V RMS (12V RMS with -12 db attenuation)
Digital Signal Processing (DSP)
DSP Crossover incorporating 6db/12db/18db/24db per octave slopes
Butterworth/Linkwitz-Riley Filters
Low Pass - 20-20Khz
High Pass - 20-20Khz
Band Pass - 20-20Khz
Q-Bass Variable 0 - 18 dB boost @ 20-150 Hz
Variable Q 0.1-9.0
Delay Variable 0-70 Msec each channel
EQ 7 Band parametric EQ/LO/HIGH shelving, each channel +/- 18 dB, variable Q 0.1-9.0
Presets 5 User Presets
Sample Rate 48 KHz
Bit Depth 24 Bit effective resolution
Input/Output Delay <3 msec with all filters flat
Control Interface
Built-In Display : 2 line X 16 character LCD display with blue backlight
Keyboard : 10 front panel buttons
USB Input
Power
Supply Voltage 9-16 Volt
Remote Power Output
2-second delay - max current 100 mA
Fuse 2.5A
...asking $400 shipped obo
Low Pass - 20-20Khz
Variable Q 0.1-9.0
Sample Rate 48 KHz
Control Interface
USB Input
Power
Remote Power Output
Fuse 2.5A
![](http://img.photobucket.com/albums/v91/97GSTAT/march09032.jpg)
jvsc300
12-17-09 04:32 PM
