IL Two Orion HCCA-D2400 Class D Mono Sub amps
Old 04-19-10, 07:23 AM
w8lifter21
w8lifter21's Avatar
Default Two Orion HCCA-D2400 Class D Mono Sub amps
These amps were in my G35 for about 2 weeks as I waited for my larger amps to arrive. It comes complete w/ everything in the box unopened as seen in the photo. This amp has a max power rating of 2400 watts, is one ohm stable, and will put out a solid 1200 watts RMS @ 1 ohm. Should you go with both amps, they can be strapped together and put out 2400 watts RMS @ 2 ohms. This amp retails for 700.00. I would like to get $300 each or $500 for the pair. Please contact me with any questions!
Orion Audio Description/Specs
The Orion HCCA-D2400 subwoofer amplifier is a Class D powerhouse, with a MOSFET power supply, heavy gauge direct-wire high current power and speaker terminals, IntelliQ bass optimization circuit and an 18dB per octave low-pass filter.
2400W HCCA High Current Competition Class D Monoblock Amplifier
2400W Class D Mono Amplifier
RMS Power Output:
4 Ohms: 425 watts x 1 chan.
2 Ohms: 800 watts x 1 chan.
1 Ohm: 1200 watts x 1 chan.
10dB of boost with INTELLi Q
Remote gain capable
Selectable AUX out
Fuse size: (3) 40 ATC
Massive loosely-regulated MOSFET power supply
IntelliQ Bass Optimization Circuit and Remote Gain Control
Heavy Gauge Direct-wire High Current Power and Speaker Terminals
18dB/octave Low-pass Filter
Dimensions: 12.6" L x 10.2" W x 2.4" H
w8lifter21 is offline
stocksc3
08-12-12 07:16 PM
SC51
02-25-11 02:50 PM
kokopuffs4
03-08-07 02:56 PM
Taka
19
05-21-04 12:53 AM
Quick Reply: IL Two Orion HCCA-D2400 Class D Mono Sub amps
