TN Audiocontrol LC6i
A lightly used Audiocontrol LC6i with box and paperwork. This allows you to add amplifiers to your factory stereo. The only reason I am selling is because I upgraded to aftermerket headunit.
This is from Audiocontrol's website:
AudioControl continues to simplify OEM integration with the new LC6i Six Channel Line Output Converter with internal summing. The LC6i is built on the same technology as its predecessor, the LC6. The LC6i converts speaker level inputs from a factory radio or factory amplifier into high-quality pre-amp signals. The addition of internal summing capabilities and improved GTO™ signal-sense turn-on make the LC6i the perfect way to solve your OEM headaches.
The LC6i allows for the addition of aftermarket processors and amplifiers while maintaining use of the factory volume and steering wheel controls. Internal signal summing and AudioControl's new GTO™ signal-sense turn-on make the LC6i a perfect OEM interface for a performance audio system.
The LC6i accepts speaker level signals, both crossed-over and full range, and converts them to high-quality pre-amp signals. Signals from factory radios with built-in crossovers can be overcome by summing them together, internally, to provide a full-range pre-amp signal.
The LC6i provides the type of clean pre-amp signals installers are familiar with. Those who desire custom control over the sound can easily add one of AudioControl's many crossovers or equalizers which offer unlimited system design flexibility, clearly different than traditional OEM interfaces.
Paid $175 new, will sell for $125 shipped.
Thanks,
Thanks,
![](https://www.clublexus.com/gallery/data/4780/PB280038.jpg)
Test Vehicle Needed For Development Stereo Replacement Kit for Second Generation Lexus IS, R&D in Process
BeatSonic
CL Vendor Products for 2IS
23
03-03-16 11:17 AM
papachulo
04-08-07 08:32 AM
rgarjr
04-14-04 03:26 PM
