NY Audison LRx 5.1MT
Audison LRx 5.1MT
Audioson LRx 5.1MT
I purchased this amp from a friend of mine thinking that I would utilize it in my car build but since then I have decided to go another route. My loss is your gain. I purchased the amp used but it is in perfect working condition. The only thing wrong with the amp is that the 2 plastic end caps are missing. I cannot remember what I did with them, if I find them I will include them. The numbering on the bottom is from my friends audio shop, he had it as an inventory number when he was selling it.
I am looking for $900 OBO plus shipping to the buyer.
Somewhat firm on the price.
Link to the manual for the amp
http://www.audison.eu/xml/products/p...MT_tech_EN.pdf
Specs from http://www.meetgadget.com/gadget/264...Rx+5.1MT/specs
Audison LRx 5.1MT specifications
Edit
General info
Car
Amplifier usage:
Power amplifier
Type:
Power amplifier
Amplified channels:
100W per channel into 4 ohms and THD 1%
Power output:
460W per channel into 4 ohms measured at frequencies from 4Hz to 0.700kHz
100W per channel into 2 ohms and THD 1%
760W per channel into 2 ohms measured at frequencies from 4Hz to 0.700kHz
4 - 58kHz at +-3dB
Frequency response:
103dB
Signal to noise ratio:
Unbalanced: 15 kohms
Input impedance:
over 190 at frequencies from 1000Hz to1kHz at 4ohms
Damping factor:
Connectivity
Unbalanced (RCA): 6
Inputs:
Analog: Unbalanced (RCA)
Outputs:
Binding post terminals
Speaker connector type:
Body
23.15 in x 2.20 in x 7.80 in
Dimensions (WxHxD):
13.22 lb
Weight:
Edit
General info
Car
Amplifier usage:
Power amplifier
Type:
Power amplifier
Amplified channels:
Power output:
4 - 58kHz at +-3dB
Frequency response:
103dB
Input impedance:
Damping factor:
Connectivity
Unbalanced (RCA): 6
Inputs:
Outputs:
Body
Dimensions (WxHxD):
13.22 lb
Weight:
loveslexus
11-14-13 04:07 PM
