CA FS: Used part - Soundstream Van Gogh VGA800.2 & Diamond 2*12 Inch Sub with box IS300
Hi everyone,
SoundStream designed and built the Van Gogh amps prior to the Power Acoustik buy-out, and are considered to be the last "real" SoundStream's ever made. They were only made for one year and considered to be very rare amps. More info and power ratings:
More info:
# RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
# STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
# Trident™ amplifier protection topology
# Ultra Low ESR Capacitance bank ensures rapid power delivery for dynamic peaks
# Continuously variable 12dB low-pass crossover (30Hz to 4kHz)
# IDI™ (Intelligent Distress Indicator) gives visual amplifier protection status
# Triple Darlington OUtput Circuitry
# Continuously variable high and low pass crossovers with 12 dB / Octave slope (30-4KHz)
# Platinum RCA Line inputs and outputs
# Platinum 4 gauge power inputs
# Rail stabilization protection circuitry
# Tri-mode operation
# BIP™ Bias Input Protection
# Harmonic Bass Alignment™ Produces tighter, more accurate bass reproduction
# Bi-Linear selectable 2 way crossovers for amplifiers and line outs
# 10Hz - 50 KHz Frequency response
# >115dB S/N ratio
# >500 Damping
# .15V - 12.0V Input sensitivity
# 0.02% THD
# Dimensions Dimensions 15.8" L X 2.6" H X 11.2"W
VGA 800.2
200x2 @ 4ohm
400x2 @ 2ohm
800x1 @ 4ohm mono
(all very conservative ratings)
I am asking for $200 or best offer.
Will ship @ buyer expense.
Diamond 12 Inch Sub with Box.
It sits very far back in the trunk.
I just do NOT remember the spec anymore.
I am asking $250 for the entire set up.
Package deal with the amp - $400 for everything!
Located in SoCal Los Angeles Area.
![](http://i156.photobucket.com/albums/t31/IS300FTW/DSC_0401.jpg)
![](http://i156.photobucket.com/albums/t31/IS300FTW/DSC_0400.jpg)
![](http://i156.photobucket.com/albums/t31/IS300FTW/DSC_0399.jpg)
thank you
Nigel
More info:
# >115dB S/N ratio
# >500 Damping
# 0.02% THD
VGA 800.2
200x2 @ 4ohm
400x2 @ 2ohm
800x1 @ 4ohm mono
thank you
Nigel
