OK Clarion 7 Band EQ EQS746
This EQ has an AUX input so that you can hook up your iPod/iPhone, DVD player, gaming system or other audio source. With a turn of the **** you can control the level of your sub to dial in that perfect sound for any listening style. Comes with mounting hardware.
•7-Band Rotary Equalizer
•12 dB Boost/Cut at 50 Hz, 125 Hz, 345 Hz, 750 Hz, 2.2 KHz, 6 KHz, and 16 kHz
•Auxiliary Input with Source Select Switch
•Adjustable Aux Input Sensitivity
•Subwoofer Output Level Control
•Gold-Plated Preamp Inputs and Outputs
•Rotary Volume Control and Fader
•6-Channel RCA Outputs
•Selectable 60/90 Hz Low-Pass Crossover
•Crossover Slope: 12 dB/octave
•Maximum Output Level: 7V RMS
•Input Sensitivity: 50mV--4V RMS
•Signal-To-Noise Ratio (S/N): 105 dB
•Frequency Response: 10-50,000 Hz
•Total Harmonic Distortion (THD): 0.005 %
•Input Impedance: 10K Ohms
•Output Impedance: 50K Ohms
•Stereo Separation: 82 dB @ 1 kHz
•Dimensions: 7" W x 1" H x 4" D
$50 plus shipping
$50 plus shipping
